Check engine light?
Old May 17, 2012 | 08:36 AM
Okie Josh's Avatar
Default Check engine light?
Put on a banks cold air intake last night and this mornin the check engine light is on! I've checked for air leaks and everything looks good! Anyone help me out?
Old May 17, 2012 | 09:05 AM
maly84's Avatar
Any chance your sensor got damaged when you were pulling it off or reinstalling it?
Old May 17, 2012 | 09:08 AM
Kermit3rd's Avatar
Have it cleared, and if there is a problem it will come back on in a couple of miles. Note code. Should be a easy fix.
Old May 17, 2012 | 09:32 AM
Okie Josh's Avatar
It could have I'll replace just to be safe!
Old May 17, 2012 | 09:44 AM
holmes4x4's Avatar
Try driving it different rates of speed (highway and around town) see if comes on and stays on, but clear it before you go out
Old May 17, 2012 | 10:41 AM
AgentK's Avatar
What code was it showing?
Old May 17, 2012 | 03:03 PM
Okie Josh's Avatar
I took it to autozone for the scan tool and they said it was an exhaust leak it's not!! But I did unhook the battery and let it set and rehooked it and it running great! I put about 100 miles and no issues. Thanks fer all the help!
Old May 20, 2012 | 05:00 AM
Okie Josh's Avatar
Well was runnin good and know its back on guess I'll have to make a trip to the dealership!!
Old May 20, 2012 | 05:36 AM
Okie Josh's Avatar
I'll check again and make sure. I'll change out the gas cap anyways!!
Old May 20, 2012 | 07:34 AM
Okie Josh's Avatar
This is the code it is throwing and if I scroll down it also says bank 2
