Check engine light on. Code PO455
For the past month or so every time I fill up, gas spills out when the tank is full. The gas handle is not clicking off. So I started it up the other day and notice my jeep was idling rough. Then the next mourning the check engine light came. Went to have the code read and it said PO455. Which I think is a evap leak. My question is, do these to things have anything in common?
Good possibility of this. I didn't want to buy a new gas cap since mine is keyed to the Jeep (factory option--one of the nice things about ordering instead of lot buying). Mine was continuing on and off for about a year, along with an occasional P0456 (gross leak). Finally someone on the forum suggested using a bit of Vaseline around the gas cap O-ring. I did and haven't seen the problem since. Been about six months now.
Edit: Here ...
http://www.autosafety.org/sites/defa...pit%20Back.pdf
Not sure what years are covered, but I have a letter from Chrysler for my 2007 extending the warranty to lifetime for the fuel fill spit-back problem. Edit: Here ... http://www.autosafety.org/sites/defa...pit%20Back.pdf
