Check List
Old Jan 8, 2010 | 11:05 AM
Dtn8rJK's Avatar
yeah i wasnt sure about the spacers. im trying to net about 3.5" of lift
Old Jan 8, 2010 | 01:12 PM
Mark Doiron's Avatar
Did you consider the TF 3" lift?
At Northridge4x4
Old Jan 8, 2010 | 02:21 PM
Dtn8rJK's Avatar
yeah, its little out of the price range for me :(
Old Jan 9, 2010 | 01:47 PM
Dtn8rJK's Avatar
Seem that you cant really go wrong with either tire. Is the only reason you say to keep away from coil spacers is to avoid driveline issues? i was adding them because i was reading some people were getting a little rub with there 2.5" coil lift thought that might clear it up a bit. how much is the avrage 2dr getting form thier tera 2.5 coil lift.
Old Jan 18, 2010 | 04:00 PM
Dtn8rJK's Avatar
buuummmp!!!!!!!
Old Jan 18, 2010 | 07:59 PM
TREDpunk's Avatar
You could skip the coil spacer and go with a 1" BL
See what the TF lifts gets ya and add the BL after if you need more.
Old Feb 18, 2010 | 12:42 PM
Dtn8rJK's Avatar
think im going to pull the trigger on this next week, but have changed a few things. the set up now is
Teraflex 2.5" coil lift
Procomp 8179 16x8 rims
315/75/16 BFG KM2
still thinking if i want the coli spacer or a body lift. or if im going to need anything at all. is there anything im missing? special tools, hardwear.
Old Feb 18, 2010 | 12:53 PM
jcs07jk's Avatar
I just installed a TF 2.5 coil lift, I got a adjustable rear track bar as I didn't want to drill the existing braket. I think on the 2 dr models you can have rear driveshaft issue if you go to high, drive shaft is to short. Someone can correct this if I'm wrong. Also did the km2 with a 15 inch wheel, love the wheels look. Have not had a chance to wheel it yet but it looks great.
Old Mar 16, 2010 | 03:44 AM
Dtn8rJK's Avatar
did it! got the 2.5" TF coil lift. instaled now just waiting on tires! everything went fine. the jeep tracks stright and no shimmy untill i hit a bump over 45mph then major death wobble, adj track bar maby?
