Chromoly Front Axle Shaft
Old Feb 20, 2007 | 06:05 AM
WranglerRubicon's Avatar
Default Chromoly Front Axle Shaft
Does anyone know if they make Chromoly Front Axel Shafts for the JK yet blew a u-joint out and wrecked both inner and outer shafts. looking to upgrade but I can't seem to find any for the JK yet
Old Feb 20, 2007 | 06:23 AM
degenerate's Avatar
as far as i know they aren't out yet for the rubi. the D30 may be the same?
how'd you do it? come on, pony up the shots of your twisted metal...
Old Feb 20, 2007 | 06:27 AM
I didn't take any pictures but I will try and get some from someone who did.
I even blew out the stub shaft on the drivers side
Old Feb 20, 2007 | 10:13 AM
you broke it on a rubi???
with stock tires???
thats sweet, i definitely need to see pics of that, with the story
Old Feb 20, 2007 | 10:46 AM
I think it was put together wrong because I haven't heard of anyone else doing that on a Rubicon with stock tires. It only has 11,000km's on it.
but I don't have any good pictures of it to share with you guys
Old Feb 21, 2007 | 03:29 AM
degenerate's Avatar
what were you doing when it happened? if it doesn't look like you were off-road, you may just want to take it to the dealer. hell, you may want to anyway. it's not easy to break a front axle, never mind a front 44. email superior and alloyusa directly and see where they're at in development. you may even get to be a test rig!
Old Feb 21, 2007 | 02:05 PM
does anyone have the e-mail for superior or alloyusa I am too lazy to look it up right now. and my slow speed internet (Dial-Up) doesn't help
Old Feb 21, 2007 | 02:16 PM
drojk's Avatar
That type of failure is absolutely unacceptable on a brand new vehicle that is supposed to have heavy duty components. If you are still running stock tires I can barely imagine a situation where even the most novice wheeler would create that type of stress.
Old Feb 21, 2007 | 02:57 PM
Rubicon Martin
Guest
Posts: n/a
There is a Link for Superior on this sites home page. They are a Sponser of Project JK. Take it to the Dealer and to have it replaced under waranty, if they find a problem with the Axles, you could cause a TSB to Open and a possible recall to benefit all buyers.
Old Feb 22, 2007 | 02:16 PM
Superior Axle's Avatar
Sponsoring Manufacturer
running through the factory right now.
Mike
