Chromoly Front Axle Shaft
Old Feb 26, 2007 | 03:48 PM
  #21
jkrubi's Avatar
Wrangler Rubicon,
Please tell us a few things - is this a JK rubicon D44 front axle that you broke? If so, how the heck did you do it? Are you running stock tires? I've seen D30s survive unnatural abuse with 37s at Moab and 21 Road - something is just not adding up here. The stock 07 Rubi D44 is supposed to have 32 spine chromoly shafts and runs larger u-joints than past models...pictures would be great!
Old Feb 26, 2007 | 04:03 PM
  #22
jkrubi's Avatar
Agree on the tacking - tons easier than getting the ears machined to accept full-circle clips and probably better. You didn't see any evidence of melted grease did you? I'm thinking you did just a tiny spot to avoid that...
Old Feb 26, 2007 | 07:38 PM
  #23
rubyred's Avatar
Sponsoring Vendor
Quadratec Rep
Default What are your complete specs
Ok so it's a 07 Rubicon
Is it 2 door or 4 door
what other modification have you made?
What was the weather like?
What gear where you in?
What 4x4 gear (2 hi, 4 hi, 4 low)
What mode of ESP did you have on?
What type of terrian?
Old Feb 27, 2007 | 04:56 AM
  #24
meeper's Avatar
Sponsoring Vendor
Quadratec Rep
we have a stock sahara at work too that this happened to in the snow, also our project jeep from Xtreme 4x4 just did the same thing....this has been happening a lot lately, we believe there is a flaw in the ESP traction system grabbing the brake to hard and 4low just breaks the shafts..
Old Feb 27, 2007 | 05:06 AM
  #25
B-MAN's Avatar
Originally Posted by WranglerRubicon
There are no clips and haven't been on the rubicons since 2003
My friend, you have no idea what you're talking about,...
There are no changes to the axle shafts from 2003 to 2006, I've worked on them all, same part# same axles,....the inners are RUBICON specific and the outer stubs are the same as the TJ D30's as are the hubs, knuckels, balljoints, inner C, etc...
I haven't played with a JK but have a hard time believing there is no retaining clip (inner nylon or metal outer c)
Old Feb 27, 2007 | 05:26 AM
  #26
WranglerRubicon's Avatar
Is it 2 door or 4 door? 4 door
what other modification have you made? no modification Everything is stock
What was the weather like? 8-10 inches of snow
What gear where you in? 2nd
What 4x4 gear (2 hi, 4 hi, 4 low) 4low
What mode of ESP did you have on? ESP OFF
What type of terrian? Snowy covered trail
Old Feb 27, 2007 | 05:28 AM
  #27
I am talking about the Snap rings they put in the yoke after the U-Joint is in to hold in each individual Cap.
Old Feb 27, 2007 | 05:37 AM
  #28
shrockworks's Avatar
Former Vendor
Holy conflicting info Batman. Here are a couple pics of my 07 JK Rubi U-joints. Looks like there is a half circ clip on the inside....
Old Feb 27, 2007 | 05:47 AM
  #29
B-MAN's Avatar
Trust me they start with them but they don't put them in the yoke, they go into grooves on the caps to keep the cap from sliding out.
Old Feb 27, 2007 | 06:12 AM
  #30
ok got ya but it still has been a problem with the u-joints loosing caps
