Clutch
Old Apr 15, 2010 | 05:46 PM
JK_2010's Avatar
Default Clutch
anyone have any ideas for a good clutch for my 2010. I think mine will go out quick
Thanks
Old Apr 15, 2010 | 06:29 PM
arkain04's Avatar
Veteran: Navy
Center Force dual friction
Old Apr 15, 2010 | 06:37 PM
jasonG's Avatar
Why do you think your clutch will go out? Mine has been strong for 50,000 miles
Old Apr 15, 2010 | 08:52 PM
GoodysGotaCuda's Avatar
x2, if you don't make it to 50k on a factory clutch. Somethin is up!
Old Apr 15, 2010 | 09:05 PM
estim8d's Avatar
Hmmm. Why do you want a different clutch? Center Force is a great choice - which I'll do if/when mine goes.
Old Apr 16, 2010 | 02:08 AM
lang1864's Avatar
Ive had a great experience with LUK. On my YJ that is
Old Apr 16, 2010 | 04:11 AM
Offroadme's Avatar
the duel friction is OVERKILL check out SPEC they have stage 1-5 but a lot of aftermarket clutches are going to feel a lot different than the stock one. just stick with the stock. or use the SPEC stage 1 i's better than the stock one. and it's a jeep not a race car so you don't need a stage 5 or anything
Old Apr 16, 2010 | 04:56 AM
King_Bogan's Avatar
i got a spec stage 3+ and reckon its great. Feels about the same as stock, except all the action happens near the release of the pedal which can take a bit getting used to.
The guys said if you do a fair bit of offroading then the stage 3+ would be the better choice as it grabs nicely and can take a bit of water between the plates if you have to use it in water (not game enough to try that one)
Old Apr 16, 2010 | 09:07 AM
Offroadme's Avatar
when you got the spec did it come with a stock release bearing of an aftermarket one. i know they don't come with the pilot bearing
Old Apr 16, 2010 | 05:33 PM
CAM24's Avatar
I have an '08 with just under 43000 miles and my clutch feels like absolute shit. I've had 3 jeeps, all with manuals, and have never had a problem with a clutch before. I'm not sure what to do about it at this point.
