co2 tank.
I have a 20lb tank for my keggerator/beer brewing. I want to convert it to be used for both tasks. The problem is my draft regulator can only do 50psi. Does anybody have a cheap regulator that would work better or can it be done without one? Also has anybody mounted one of these in a 2 door. I am considering getting a bracket to attach it to the roll bar hope fully above the sub but the fitment will be very snug. I am looking for the cheapest solutions. Thanks in advance for the always great info. Also if there is anything else i am missing about this co2 system please let me know.
I just bought a complete system from offroadair.net for my 2 door, and I just mounted it over the subwoofer. I had to trim the foam under the zippered cover, but otherwise it was easy. On their site, they sell the 150 psi regulator for $50, and you can buy the holder and brackets, too.
I bought the roll bar mounts (not cheap, $54) that I attached to the roll bar above the subwoofer, then the tank bracket to the mounts. I looked for some way to attach my 5lb tank from my kegerator (I have a spare), but didn't find anything. granted, I am not a fabricator. I will post some pictures later this week.
I do not have pictures of it yet, maybe by friday. I haven't even filled the tank yet. I bought it because funn4lo had a system he put together (with the regulator from offroadair). It takes about 30 seconds per tire to air up, and one 10lb tank will do 35+ tires. My one concern will be the heat out here in SoCal.
