co2 tank.
Old Mar 5, 2008 | 05:10 PM
Pete799's Avatar
Default co2 tank.
I have a 20lb tank for my keggerator/beer brewing. I want to convert it to be used for both tasks. The problem is my draft regulator can only do 50psi. Does anybody have a cheap regulator that would work better or can it be done without one? Also has anybody mounted one of these in a 2 door. I am considering getting a bracket to attach it to the roll bar hope fully above the sub but the fitment will be very snug. I am looking for the cheapest solutions. Thanks in advance for the always great info. Also if there is anything else i am missing about this co2 system please let me know.
Old Mar 5, 2008 | 05:27 PM
kerryp's Avatar
Do a google search for OffRoadAir Hyper-Flo 150psi Fixed Regulator , they have a couple different units ranging from 49 and up.
Old Mar 5, 2008 | 05:34 PM
Jared937's Avatar
I just bought a complete system from offroadair.net for my 2 door, and I just mounted it over the subwoofer. I had to trim the foam under the zippered cover, but otherwise it was easy. On their site, they sell the 150 psi regulator for $50, and you can buy the holder and brackets, too.
Old Mar 5, 2008 | 05:40 PM
Pete799's Avatar
Thanks for the speedy responses. Jared937 do you have any pics and what did you use to mount it, what did it attach to?
Old Mar 5, 2008 | 05:47 PM
Jared937's Avatar
I bought the roll bar mounts (not cheap, $54) that I attached to the roll bar above the subwoofer, then the tank bracket to the mounts. I looked for some way to attach my 5lb tank from my kegerator (I have a spare), but didn't find anything. granted, I am not a fabricator. I will post some pictures later this week.
Old Mar 5, 2008 | 05:49 PM
Pete799's Avatar
What size tank did you buy?
Old Mar 5, 2008 | 05:54 PM
Jared937's Avatar
10lb. But they do sell 20lb brackets. Again, not cheap, but real pretty!
Old Mar 5, 2008 | 06:15 PM
Pete799's Avatar
Do you have any pictures because that would be great? Thanks for the info. Also how do you like the co2 tank system?
Old Mar 5, 2008 | 06:31 PM
Jared937's Avatar
I do not have pictures of it yet, maybe by friday. I haven't even filled the tank yet. I bought it because funn4lo had a system he put together (with the regulator from offroadair). It takes about 30 seconds per tire to air up, and one 10lb tank will do 35+ tires. My one concern will be the heat out here in SoCal.
Old Mar 5, 2008 | 08:31 PM
Pete799's Avatar
Sounds awesome cannot wait to see some pictures.
