Coast Front Driveshaft Install
Old Jul 30, 2012 | 05:11 PM
williard86's Avatar
Default Coast Front Driveshaft Install
Hey guys,
My Coast 1310 front driveshaft arrives tomorrow. I was planning on installing it myself but I've been reading alot about pinion preload and crush sleeves. I've also read where people have been just using 160 ft/lbs. and calling it a day. Is this an acceptable method? I don't have access to a needle type torque wrench nor do I know how to check the preload. I guess what I am asking is, Should I just take this to a driveline shop or would they just do it the easy way (i.e. not checking preload).
Thanks in advance.
Old Jul 30, 2012 | 05:38 PM
Rich6700's Avatar
With no automotive experience, I would take it to a transmission shop or a automotive repair shop and have it installed.
Old Jul 30, 2012 | 05:39 PM
Atch's Avatar
Project jk has a driveshaft write up on their site which makes the install look pretty simple
Old Jul 30, 2012 | 05:50 PM
HCSTHS43's Avatar
Maybe I just got lucky, but I installed mine myself using the directions on project jk and have had zero issues in 3 months. Used 4wd about 4-5 times over this time.
Old Jul 30, 2012 | 06:19 PM
williard86's Avatar
Default Thanks for the response
It's not that I have NO automotive experience, I have never done this before and don't know if the whole preload check is necessary. I'd like to save some dough but you may be right.
That is the installation I was planning to follow
How many miles have you put on the jeep since you've done it? I've read a lot of comments just like yours. They always seem to start with "Maybe I'm just lucky" haha.
Anybody else install their own without setting/checking the preload?
Old Jul 30, 2012 | 06:27 PM
HCSTHS43's Avatar
I don't drive real far, so only about 2200 miles on it so far, with about 5 or 6 hrs of offroad driving using 4wd
Old Jul 30, 2012 | 06:30 PM
HCSTHS43's Avatar
I was kinda of nervous about it for a bit, and then just kinda said what the heck and went for it. Whats the worst that could happen
Old Jul 30, 2012 | 06:52 PM
williard86's Avatar
Haha...I think you can destroy the pinion if I'm not mistaken. I'm going to call a few places in the morning and see what they'd charge. if its more than I want to pay then I'm gonna go for it. I need my 4 wheel drive back dammit!
Old Jul 30, 2012 | 06:56 PM
hypeiv's Avatar
I followed the guide on project jk and had no problems... check the spicer joint when you get yours and make sure all the lock rings are secure.
You can do the install with the jeep on the ground which might be easier b/c if the front wheels are off the ground you will need someone to step on the brakes (with engine on for power) when you torque down the axle output joint... i think if its on the ground and you have the parking brake on you could prolly torque without any help.
Old Jul 30, 2012 | 07:56 PM
williard86's Avatar
Default thanks
I saw where the guys snapped one because of the lock ring. Thanks for the tip.
Any greasing I should do on the spline or other wise?
