Coil removal
Old Feb 27, 2010 | 06:29 AM
frankie945's Avatar
Spring compressors are totally safe if you use them properly. I have used them for many applications.
Old Feb 27, 2010 | 07:54 AM
mkjeep's Avatar
x2........
Old Feb 27, 2010 | 08:10 AM
sktdarkstar8's Avatar
well see the thing is that i am removing TF 2.5in coils and installing a inch big spacer. when i installed them previously i used a coil compressor but it was a older tool and took awhile. ive used the compressor in the past so i am familiar with them but was wondering if theres a better and newer version of the comprssor to make the job easier.
if i do all the things above to drop the axle lower to put the springs in, even with a 2.5in coil then adding a one inch spacer, u guys dont think i need a compressor?
Old Feb 27, 2010 | 08:39 AM
mkjeep's Avatar
Fronts can be a bitch, I got my compressors from Sears. Worth their freakin weight in gold if you ask me. Make it alot easier to put that spacer in.
Old Feb 27, 2010 | 11:45 AM
What do the compressors look like.. There are a few different kinds and I just want something that won't be a pain to use like my old compressor
Old Feb 27, 2010 | 12:46 PM
mkjeep's Avatar
what do the compressors look like.. There are a few different kinds and i just want something that won't be a pain to use like my old compressor
Old Feb 27, 2010 | 01:32 PM
jmat1980's Avatar
Get a spring compressor, It suscks if you dont have it and need it. They are available for rent FREE from Autozone. You just need a credit card deposit. They are not dangerous if used properly. It will make life easier when replacing the springs (prob not needed for removal).
Old Feb 27, 2010 | 06:08 PM
wheezer's Avatar
Originally Posted by mkjeep
x2........
X3...Check some of your local auto parts stores to see if they loan them out. I know Autozone and PepBoys do it out here.
Old Feb 28, 2010 | 02:01 PM
_J__C_'s Avatar
I'll be putting in my new rear springs next week sometime and may just go to Autozone and rent some. Do they compress enough that i wouldn't have to unbolt everything? Maybe just unbolt the rear shocks and jack the back of the Jeep up?
Old Feb 28, 2010 | 03:14 PM
frankie945's Avatar
How tall springs are you putting in? You might not need a spring compressor for the rear if it's only a 2.5 lift. I know I didn't use a compressor for the rear just for the front.
And you will still have to losing up some bolts to get the axle to flex a bit more for the install. The rear is much easier to do then the front.
