Which coil spring?
As I swapping part of my 3'', I just ordered a set of front/rear ORE's King shocks to replace my G-force FT, I would like to know what could be the best replacement form my coil spring? I originally have 3'' FT coils.
Are you getting the coil overs or just shocks? If your getting coil overs then you won't need separate springs.
Update, Andrew @ ORE told me that they tested this shock with great result with pretty much every major manufacturer of spring including TF, FT and OME HD.
Keep you posted when install and test drive done.
