Coil spring shift
I've noticed a couple of times now after I've gone wheeling, that my rear coil spring in the rear driver side keeps shifting on the upper "isolator" (?). I'm not sure if that's what it's called...sounds good in my head for now. I've had to jack my jeep up enough twice now to where there isn't any pressure on the suspension so I can move it back. It rubs a little on my rear track bar bracket and has worn the paint off the spring in one spot. Are there any easy ways to fix this? It's just annoying really. I can try and post a pic later on.
Your shocks are a little long for your springs. Just buy some spring retainers and you'll be fine.
http://www.northridge4x4.com/proddet...807RRK&cat=273
Thanks again
Look at that! Awesome, thank you. Anyone happen to use these at all? or have any pics with them installed? I just have to figure out what I'd have to do to install them. I live in a condo so I'd like to see if I have to go to a garage and use a lift or if I can just bolt it on in the parking spot.
Thanks again
Thanks again
thanks
Thanks again
Thanks again
To be honest I'm not too sure....I think they are a little tighter up top, I'm kind ofhoping someone else will tell us though.
I actually found AEV's forum and have found that this is an issue that a lot of people are having with this lift because the shocks are pretty long compared to the springs. Apparantly the majority of people are getting the Teraflex .5" coil spacer. It sits on top and has a nipple type design that guides the springs back in place. I think I'll probably be doing this option.
I'm hoping this fixes it because when My springs are off a little they start to bow and it's a nuisance to have to lift it up and adjust the springs after every wheeling trip.
If anyone does anything different please post. I'd like to hear.
Maybe you need shorter shocks or a set of these ...
I actually had the same problem and solved it with shorter shocks. More in this thread ...
rear spring shifted out of place - is this common?
while i am not running aev springs, i heard of others having this issue with the rear springs dislocating and i took preventative steps. i installed the upper spring retainer from currie (very robust clamps and bolts)and used the lower spring retainer that came with the teraflex kit.
