Coil spring shift
Old Sep 1, 2010 | 01:19 AM
Mark Doiron's Avatar
Originally Posted by VaNomad0530
... my rear coil spring in the rear driver side ... rubs a little on my rear track bar bracket and has worn the paint off the spring in one spot. ...
Is it possible that the RockKrawler wedges might help? In addition to shifting the spring perch closer to level, it would give you about 1/2" more of spring height.
Here's a related thread ...
Anyone Using the Rock Krawler Wedges and JKS Spring Retainer?
I have the wedges and they fixed the rub between the 2.5" TF spring and JKS trackbar (passenger's side).
Old Sep 1, 2010 | 05:00 AM
JK-Rubi's Avatar
Default Currie Spring Retainers
Anyone happen to use these at all? or have any pics with them installed?
Old Sep 1, 2010 | 07:26 AM
VaNomad0530's Avatar
Originally Posted by HG07JKRubi
Maybe you need shorter shocks or a set of these ...
I actually had the same problem and solved it with shorter shocks. More in this thread ...
rear spring shifted out of place - is this common?
Yup, I think I'm going to be going with these. They're the teraflex half inch Rear coil spring spacers.
Thought about the shocks, too pricey though and I have good shocks too
Originally Posted by mkjeep
I use the Teraflex nipples. They're nice. Once you go long nipple, u settle for nuthin less.
.....god bless nom nom's ...I mean long nipples....I MEAN Teraflex's Coil spacer and long nipples!
I've been tempted to do this as well. The only thing that's prevented me from pulling the trigger is when my coil is seated correctly up top, it's relatively straight. I think I'll do the spacer and then see how it goes after that. If it still decides to start bowing out I'll be doing this as well. Hopefully it won't jeopardize the ride.
As for the Currie retainers....I've read that the bottom portion fits the AEV springs, but not the top
I'm thinking now I should've renamed this thread to; Quirks about AEV's "Premium" lift....In fact I may start a different thread for this
Old Sep 1, 2010 | 07:34 AM
TeraFlex's Avatar
Sponsoring Manufacturer
Originally Posted by Texas Trailmaker
while i am not running aev springs, i heard of others having this issue with the rear springs dislocating and i took preventative steps. i installed the upper spring retainer from currie (very robust clamps and bolts)and used the lower spring retainer that came with the teraflex kit.
I would suggest not running a upper and a lower coil retainer. You can end up damaging the coil or the retainers. It's better to retain only one end, so your coil doesn't get tweeked from being pulled on at both ends.
Old Sep 1, 2010 | 09:09 AM
JayhawkJeep's Avatar
Veteran: Navy
So is it better if the coil unseats
Old Sep 1, 2010 | 09:24 AM
TeraFlex's Avatar
It's ok if it unseats, it's not ok if there's no way to guide the coil back to frame, or some type of retainer on the axle end.
Old Sep 1, 2010 | 09:37 AM
CA-JK's Avatar
How is the top of AEV springs different then any other spring?
I'm pretty sure they're progressive springs, so the top of the springs probably don't have enough room for the clamp to fin in between the coils.
Old Sep 1, 2010 | 11:17 AM
BuckLisa's Avatar
Well, my Currie lowers are installed, now I got to get the Teraflex 1/2 spacers to put in! It appears having the loose spring with a nipple guide, but having the lowers locked down seem like a safer alternative to having both locked down. I guess my progressive springs prohibiting the Currie uppers from fitting up top is a blessing in disguise.
Old Sep 1, 2010 | 11:18 AM
Unhappy
So then is your recommendation to get a retainer for the bottom and use your guys half inch coil spacer with the long nipple type thing on it? and also I don't want any more lift in the rear end so is the half inch about the same size as the stock one? I mean, if it's raised up another half inch in the back I'm not going to lose sleep over it, just curious though.
Thanks for the help by the way
Old Sep 1, 2010 | 11:26 AM
By the way, not to hijack my own thread, but.....what gives with the unhappy face on my last post in the upper left hand corner? ....ok back to topic.
