Compresso ARB Help
Old Apr 1, 2010 | 11:53 AM
kozz's Avatar
Default Compresso ARB Help
I can not run the ARB compressor!! can someone help me??
Old Apr 1, 2010 | 11:54 AM
frankie945's Avatar
Be more specific.... They do carry a 24v system if that's what you mean...
Old Apr 1, 2010 | 11:57 AM
kozz's Avatar
The new ARB compressor complements the earlier, without replacement, designed specifically with the possibility of inflation wheels.
Key Features:
- Firefox is completely sealed to withstand dust and humidity
- Ultra compact design to insert it into tight areas where most other compressors will not enter
- The pressure is calibrated to operate the locks
- The cylinder with the shirt and anodized piston with sealing rings ensure a long-term carbon
- Air cylinder
The new support allows, anodized aluminum heat sink and allows you to mount the compressor completely reversed.
Available in 12V complete wiring.
Old Apr 1, 2010 | 12:03 PM
NVRSTUCK's Avatar
What are you talking about??
Old Apr 1, 2010 | 12:23 PM
frankie945's Avatar
google 24v arb compressor. You will find info on it. I'm guessing that's what you mean.
Old Apr 1, 2010 | 12:31 PM
kozz's Avatar
give me a hand with wiring!! thanks
Old Apr 1, 2010 | 01:31 PM
frankie945's Avatar
Did you get a diagram it shows where everything goes. It's a real easy install. Only took me 35min to install bracket compressor and all switches and wiring.
This might help you some.
http://project-jk.com/jeep-jk-write-...ation-write-up
Old Apr 2, 2010 | 07:52 AM
Bennyhana's Avatar
The red wire that comes off the switch wiring does need to be hooked up to a 12volt source...
Old Apr 2, 2010 | 08:06 AM
frankie945's Avatar
I would have to look at the diagram again.. But I think the red/yellow wire goes to a ing wire . Not a constant 12v but don't hold me to it.
