control arm dilemma
Old Dec 13, 2010 | 12:36 PM
Dark_Star's Avatar
Default control arm dilemma
so, i m about to pull the trigger on a 2.5" or 3" lift for my 09 jku! Here's my dilemma: one kit comes with just adjustable LOWER control arms and the other with just adjustable UPPER control arms. My question: is one better for adjusting the axle angles then the other, or does it not matter just as long as one of them is adjustable?
Old Dec 13, 2010 | 12:38 PM
Pluke the 2's Avatar
I choose the front lower to adjust caster.
Old Dec 13, 2010 | 12:41 PM
rinkishJK's Avatar
Front lowers here too. Teraflex arms!! Much beefier than stock.
If u get uppers I think only the curries adjust short enough to adj caster. I would choose lowers.
sent by the rinkish with tapatalk power!
Old Dec 13, 2010 | 01:06 PM
wayoflife's Avatar
JK-Forum Founder
technically, upper arms are intended to set caster and lowers the position of your axle. however, if you can only get one set, adjustable lower arms will do the job just fine by themself, are easier to install and will give you a greater range of adjustment.
Old Dec 13, 2010 | 01:37 PM
jeepmedic's Avatar
If you can get the uppers and lowers, I would since you have to take it all apart anyways
