Control Arm Drop Brackets? Yes / No?
Old May 15, 2014 | 06:21 PM
  #21
Mango881's Avatar
Originally Posted by Sahara Lee
I installed the Rancho 4" Sport Lift last summer. It comes with the Rancho relocation brackets which I personally think are better constructed than the others. My caster is 4.7 with the 4" lift and stock control arms. Steering is solid at highway speeds (70mph).
Rancho RS6250B - RANCHO® Control Arm Bracket for 07-14 Jeep® Wrangler & Wrangler Unlimited JK with 3-4" Lift - Quadratec
I'm not sure how they would work with 2.5" lift but I'm sure Rancho tech support would be happy to field your questions.
I noticed a post above from someone who may have removed adjustable control arms and switched to relocation brackets. Why would anyone do that? It's all about the geometry.
When you lift you increase the angle of the control arms because the trailing end is now higher than the leading. More lift equals more angle. Now, when you hit a bump at highway speed, the wheel doesn't just travel up but also must travel forward as it moves up. The counter-force to the wheel forward motion pushes on the Jeep frame and is felt as a bump from the front, an uncomfortable jerky motion. You will never experience this on the trail. It only happens at highway speed.
The relocation brackets reduce the control arm angle so they restore ride comfort on rough roads at speed.
At least that's my story and I'm sticking to it. Your mileage may vary.
I was the one who had adjustable control arms and put brackets on with a 4 inch lift. You had an excellent explanation about the benefit of the brackets which is everything that I read about before also.
That explanation answers your own
question as to why someone might switch from adjustable to brackets. Control arms allow you to dial in your caster but do nothing about the geometry to absorb the road as you explained unless you have a long arm kit.
I agree that a 2.5 inch lift might not make as big of a difference though.
But hey, that's my story. Lol
Sent from my SAMSUNG-SGH-I317 using JK-Forum
Old May 15, 2014 | 07:08 PM
  #22
Bypass's Avatar
Since you won't crawl, the brackets will be fine. Cam bolts too as long as you tighten the hell out of them. I'd personally spend the $ and get some adjustable arms and the brackets.
You also need to make sure your toe is IN about 1/16-1/8. I'm willing to bet if it's flighty, then you are at zero or toes out some.
Old May 15, 2014 | 07:22 PM
  #23
Hoopskier's Avatar
Val 2.0- I have the exact same setup as you, '13 JKU with Teraflex 2.5, Monster track bar, Kelly TSR tires.
I put drop brackets in mine. I went with the Rancho brackets, RS6250B. I picked them up for $120 online, just slightly more than the AEV. I liked the one piece design. Easy to install in the garage, don't even need a jack, just do one side at a time. As long as you have the tools to tighten the lower control arm bolts.
If you are putting in the brackets, it would be a good opportunity to intall the 9/16 bolt kit to replace the slightly undersized OEM metrics. Cheap peace of mind, about $40. Northridge sells a kit, but I sourced mine out locally through Fastenal.
Old May 15, 2014 | 08:37 PM
  #24
TheDirtman's Avatar
Drop brackets make sense for what you are looking for. No need for aftermarket arms. They will offer you more then just caster correction as stated above.
Old May 15, 2014 | 09:30 PM
  #25
Tripletsi's Avatar
Originally Posted by Val 2.0
For about $100 (AEV) the ride will dramatically improve (allegedly)
I didn't believe it myself as well but I instantly felt the difference after installation. I drove the same roads where I encountered bump steer previously (plenty in Pittsburgh) and experienced a much smoother ride. You could feel the suspension sucking up the bumps and the jarring sensation was not being transferred to the frame anymore. Great investment for only $100.
BTW these do work if you have the EVO Protek system. Just some fighting and swearing involved.
Old May 16, 2014 | 05:35 AM
  #26
Val 2.0's Avatar
So did the ride quality improve as others have stated? Don't get me wrong it's not horrible by any means, just want to improve it if possible... will probably wait a few months though, going on vacation next week then will more than likely be packing up the house getting ready to move...
Thanks again everyone! I really appreciate all your input! This is such a great forum, so much knowledge!
Old May 16, 2014 | 07:44 AM
  #27
Hoopskier's Avatar
I thought the ride improved, no caddy, but better. Like others have mentioned, with the drop brackets it seems to make the suspension work more to soak up the bumps. I put them on again.
Old May 16, 2014 | 08:57 AM
  #28
Rancho's Avatar
Sponsoring Manufacturer
Here is the info on ours:
Easier install than some others.
Beefier than most too.
Works for 2.5 to 4" systems out there.
Good luck in your choice.
Old May 16, 2014 | 09:05 AM
  #29
TxJeepers's Avatar
Skip the brackets, keep the factory lowers with their great road absorbing bushings and replace the uppers with adjustables to dial it back in. You can get a set of Metalcloak uppers for 205 and they include the replacement bolt.
Old May 16, 2014 | 09:26 AM
  #30
LidLess07X's Avatar
I disagree. If the OP is looking to improve ride quality, and isn't rock crawling, the brackets will provide a much smoother ride.
