Control arm mount....Bent it...
Okay...out wheeling Saturday at Creekside Edge and bent my driver side lower control arm bracket. Dealer says you have to replace the axel. Not gonna happen. I just had them replace the damn thing on July 10th when I bent it out in Logadale, Nevada. So two axels in right over 2 months...I think not. I'm thinking I find a weld shop and have them weld on a new fabricated one. Heard this is ok...any thoughts from you all. I can't afford a new axel at the moment so thinking this is my best shot. If so...anyone know a shop who can do it in the Houston area? Also...having to run with no sway bar connected since it won't re-conectt since the bent mount has the front end out of whack big time...freaking stability control is going nuts when I forget to turn it off. As always...any help or thoughts on my latest predicament will be greatly appreciated.
Thanks-Mike
Thanks-Mike
Well...off to call some folks tomorrow and see who can weld a fix for me. Anyone know if 4 Wheel Parts does this kind of work. I know they do installs and what not...but not sure if they do welding work.
Thanks-Mike
Thanks-Mike
Yeah I had the same thing happen to me a few months ago using the edisco the rubicon came with. The dealership recommended that I replace my front axle as well. i ended up just doing an insurance claim and they fixed all kinds of things. just remember to manual disconnect your sway bars if your doing anything serious.
Definitely would help, it makes them a box structure which is much stronger. At this point I would not repair these as you will only re-damage them. There are some companies that make replacement LCA mounts which are made of 1/4" steel already boxed for about $45 for a pair. I would order those and then take the Jeep to a 4x4 shop or a frame/front end shop to have them installed. Search the internet for "Jeep JK Front Axle HD Lower Control Arm Mounts" to find some.
