Control Arm question
Old Jul 2, 2013 | 06:58 PM
TaylarsJK's Avatar
Default Control Arm question
I'm installing my Rusty's adjustable front lower control arms tomorrow and have a couple of questions before I do it.
1. Do I have to use a floor jack at all or do I keep the wheels on the ground?
2. Will I have to get an alignment after the install?
Thanks!!!
Old Jul 2, 2013 | 07:46 PM
Smashboogie 4x4's Avatar
Former Vendor
You can do it with all the wheels on the ground. We always recommend having the alignment at least checked. This will give you a more accurate castor setting so your rig is more enjoyable to drive.
Old Jul 2, 2013 | 08:33 PM
JDub23's Avatar
Recently upgraded mine, and left all 4 paws grounded. Will note that mine were fixed though.
~JDub
Sent from this Dang Thing
Old Jul 2, 2013 | 09:02 PM
k0260's Avatar
Thanks!!!
Left mine on the ground to install all 8. Dialed in caster/pinion and set the toe. Came out Perfect.
Old Jul 2, 2013 | 11:08 PM
Bxjk's Avatar
Is there a write up for castor and pinion as well as toe adjustments ?
Old Jul 3, 2013 | 01:22 AM
kjeeper10's Avatar
Vet Army
Synergy is known to have good numbers to start with. Every jeep is a little different so your settings might be different then somebody else's.
All 8 arms ?
Generally the front lowers center the wheel in the wheel well at 23" eye to eye.
Uppers for caster/pinion. You can base caster off your pinion flange knowing there's 6* of separation. 2*-2.5* up will give you around 4*-4.5* caster.
The rear lowers center the axle in the well, rear uppers to have the pinion - 2* less than the driveshaft angle.
Old Jul 3, 2013 | 01:42 AM
Bxjk's Avatar
Thanks for the tips. I'm gonna have to try and install as soon as I get a chance
Old Jul 3, 2013 | 09:05 AM
TaylarsJK's Avatar
What do I torque the bolts to?
Don't tread on me.
Old Jul 3, 2013 | 11:10 AM
kjeeper10's Avatar
Vet Army
All CA's/Tb bolts except front uppers are 125, front uppers are 75 ft lbs.
Old Jul 3, 2013 | 03:03 PM
TaylarsJK's Avatar
Thank you very much
Don't tread on me.
