Control Arm question
Old Jul 3, 2013 | 04:04 PM
bbrown626's Avatar
Originally Posted by kjeeper10
The rear lowers center the axle in the well, rear uppers to have the pinion - 2* less than the driveshaft angle.
This pinion angle guidance is not applicable to stock drive shafts.
Also, watch your springs and track bar. a higher pinion angle will cause the springs to bow quite a bit. A lower angle may push them into the track bar.
Old Jul 3, 2013 | 07:12 PM
kjeeper10's Avatar
Vet Army
^ and why wouldn't it ?
You still want the lowers to center the axle, which leaves the uppers for pinion angle.
For the bowing, a cheap easy fix is correction wedges. Best way to do is cut and relocate the perches.
