control arm relocation brackets
Old Nov 9, 2011 | 08:18 AM
Schwheelz's Avatar
Default control arm relocation brackets
Does anyone know the downsides of these? Rough country sells them for the front. Do you know where I could pick some up for the rear?
Old Nov 9, 2011 | 08:25 AM
Schwheelz's Avatar
So it's best to just grab the adjustables?
Old Nov 9, 2011 | 08:30 AM
Schwheelz's Avatar
That makes sense. Thanks for the input!
Old Nov 9, 2011 | 08:32 AM
ranjr's Avatar
Originally Posted by GON WHLN
Down side is ground clearance if these lower your LCA's. In the stock position they hit thigs already so most people skid the control arm mounts. Now imagine lowering them 2 inches +.
Bad idea in my opinion
Wouldn't that put them in the stock location if a 2" lift is used?
I think they are used to get the angle of the arms back more horizontal for better drivability. This helps over bumps by allowing the axle to move up instead of back.
Old Nov 9, 2011 | 12:59 PM
Schwheelz's Avatar
I really like that point, for the cost of the relocation brackets it seems fairly worthwhile. I can weld too, so if I feel like putting some skids on that would also be possible
