Control arm skids - bolt or weld
Old Jul 29, 2009 | 05:01 PM
Steve Young's Avatar
Originally Posted by GoodysGotaCuda
What is the proper install of the welded supports? Have the control arm/shocks bolted in and torqued, just the bolt through and torqued? There is a bit of flex in the shock mounts I know between it being empty, and torqued down..
That's a question I'd like to know the answer to as well. One of the things I realized (not totally related) was that to fit the Clayton CA's you need to do a little cutting on the original mounts so it makes sesne to do that (and at least test fit the new CA's before welding the skids.
Whether the skids are better welded with the CA's removed (which reduces the chance of cooking the bushings) or whether you should have them all torqued up
Steve
Old Aug 19, 2009 | 04:45 AM
kflash's Avatar
Adrenaline Offroad here in Maryland are welding no the EVO C gussets and front control arm skids when they do my 5.13s (hell yes!) gears next week! Can't wait!!!!
Old Oct 27, 2013 | 06:54 PM
HardRooster's Avatar
Do you disconnect the lower control arm before welding, or are the rubber bushings safe from burning/melting?
Thank google for me resurrecting this ancient thread
Old Oct 28, 2013 | 08:05 AM
ABENDX's Avatar
Maybe I am missing something.... but isn't this basically a rectangle?
Old Oct 28, 2013 | 08:13 AM
BRUT4CE's Avatar
Former Member
Fronts can be done with the arms in place just cool Ema Dan don't run a long bead it'll smoke bushings.
Rears I'd disconnect the shock and arm because of the overlapping proximity of where you will be welding.
Do 1 at a time (disconnect) and then to the next in rear.
It is super simple a installer can do either easily....evo has made it idiot proof so as synergy
Old Oct 28, 2013 | 12:13 PM
Boyerracing343's Avatar
Another vote for weld on.
Old Oct 29, 2013 | 09:28 AM
Flyingbrian's Avatar
Bolt on
Old Oct 29, 2013 | 10:17 AM
xj-boonie's Avatar
Where are they and how much is it running ya?
Old Oct 29, 2013 | 04:15 PM
mattyk's Avatar
Veteran: Navy
artec industries. I ordered my axle armor through them. looks freakin mean, DEFF strong, came with gussets and control arm skids for around 250ish all together. im not dispointed and hold no regret...minus the fact that I wish I could have welded them on myself...
