control arms
Old Sep 3, 2010 | 11:31 AM
HornetJK's Avatar
Thank you for this information. I just completed my lift and this thread helped me alot.
I think this should be added to the Project-Jk Jeep JK write up section. Pass this on to Wayalif.
Old Sep 3, 2010 | 03:17 PM
Joisey's Avatar
that should be added to the faq's
Old Sep 3, 2010 | 04:59 PM
gfe jeep's Avatar
Default Thanks Planman!
Great reading for me too
Old Sep 4, 2010 | 09:33 AM
BrowniesJK's Avatar
Great info.
Old Oct 8, 2010 | 04:57 PM
jeeper2008's Avatar
What about control arms on a 3.5"? Still do adj. lower fronts and adj upper rears?
Old Oct 8, 2010 | 05:21 PM
aermotor's Avatar
I just installed a Tom Woods on my front and despite the angle being off did not need adjustable front arms. Perhaps in the future when I have to get a pair for the rear shaft I will.
Old Oct 8, 2010 | 06:51 PM
blazenjeep's Avatar
I HAVE A 4IN ROUGH COUNTRY LIFT GOING TO BUY FRONT DRIVE SHAFT THIS WEEKEND WHAT CONTROL ARMS DO I NEED AFTER ALL U SAID ???
Old Oct 8, 2010 | 07:52 PM
aermotor's Avatar
What type of driveshaft are you buying? Most likely you will need nothing.... I have a 4"-6" lift and did not end up needed adjustable arms. Runs smooth as can be in 2WD and 4WD. If you want to spend the money either way, all you need is front lowers.
Old Oct 8, 2010 | 08:44 PM
joeydude's Avatar
I'm glad I'm not the only one... I've been contemplating all the options... lower this, upper that... front or rear... drive shaft now... drive shaft later???
My front drive shaft has started spitting grease.. so I need a new drive shaft but not sure which control arms to buy...
I have a 2dr manual with 3 inches of lift... Whats everyones 2 cents on this? uppers, lowers or none?
thanks, the above info was very helpful.
Old Oct 8, 2010 | 09:02 PM
j2d013's Avatar
Originally Posted by planman
The upper rear arms are used to adjust the pinion angle of the rear axle when you add an aftermarket driveshaft:
The lower rear arms are used to lengthen your wheel base that is lost when you lift your rig. See how the rear wheels on this rig are more forward than stock because it was lifted 4" without rear lower control arms:
The front lower arms are used to either regain lost wheel base from a lift or to adjust the angle of the front axle for correct caster alignment, or both.
The front upper arms are used to adjust the angle of the front axle for correct caster alignment specs if the front lower arms were used to regain wheel base.
In some circumstances--like with the Currie adjustable front upper arms--front arms can be adjusted much shorter than stock for correct caster alignment specs if the stock arms are still used.
Caster shown in lower left corner:
So:
  • There is no need for rear upper adjustables unless you run an aftermarket driveshaft.
  • There is no need for rear lower adjustables unless you feel a need to lengthen/regain your lost wheelbase caused by your lift.
  • If you run Currie adjustable front uppers to adjust your caster specs, there is no need for adjustable lowers unless you want to fine tune your alignment or lengthen your wheelbase.
  • There is no need for adjustable front uppers if you can properly correct your caster alignment specs with adjustable lowers.
At 2.5" to 3", you can go with either adjustable front uppers or lowers to inprove your caster specs.
At 3" on a 2 door, you may eventually need to run an aftermarket driveshaft along with adjustable rear uppers.
In either case, at 2.5"-3" there is no need for all 8 adjustable arms, and the money could be better spent on other upgrades.
WOOOOOW... I have been wondering about all this and you Sir just answered all of our questions in a simple easy to read & understandable post. Thanks a ton for your info,It is amazing the know how people have about theses JK!!!! Great post!!!!!!!!!
