Control Arms??
Old Feb 11, 2011 | 04:19 PM
blazenjeep's Avatar
VERY TURE BUT I JUST CAN'T FIND THE STOCK BOLTS...
Old Feb 11, 2011 | 04:30 PM
wayoflife's Avatar
JK-Forum Founder
you know, you can just use a grade 8 SAE equivalent
Old Feb 11, 2011 | 04:34 PM
blazenjeep's Avatar
you know, you can just use a grade 8 sae equivalent
ive checked at the depot and lowes but no luck yet.what would i need to put in place to weld those cut outs back in .
Old Feb 11, 2011 | 04:48 PM
NVRDUN's Avatar
OMG....I am so confused now
I just want to know if I NEED front and rear upper and lower adjustable control arms.
Old Feb 11, 2011 | 04:51 PM
wayoflife's Avatar
JK-Forum Founder
go to an OSH, ace hardware or true value and look at their specialty hardware drawer section. you should be able to find a 12mm grade 10.9 washer or 9/16" grade 8 washer to weld on to your control arm mounts. for replacement bolts, you can use a grade 12mm x 4" grade 10.9 bolt and nut or 9/16"x4" grade 8 bolt.
oh, i see you are in montobello, you might want to go to downey and check out all american home center on firestone blvd. they will have what you need.
Old Feb 11, 2011 | 04:54 PM
wayoflife's Avatar
JK-Forum Founder
you may not need both but both will help you dial in your front end well. the lowers will allow you to set the position of your axle and the uppers will allow you to set your caster. if you do have cam bolts installed, you will need to get your lower control arm mounts at the axle repaired with a set of washer welded in place to make the slots holes again. does this make sense?
Old Feb 11, 2011 | 06:04 PM
blazenjeep's Avatar
COOL THANKS EDDIE....
Old Feb 11, 2011 | 08:29 PM
mattgt5's Avatar
I am installing the Pro comp 4" lift next week on my 2010 JKU. Everything I could find said that the rear track bar bracket works great. They all also said that new adj LCAs and a new adj front track bar were a must. That is what I went with and will be installing, thanks to this wonderful forum.
