Control Arms ?!
you should add more caster up front, no it will not matter if you are running 32's or 35's and no, you should not have any excessive driveshaft wear with it. if you have not replaced the rear shaft, it being so short and being at an extreme angle will cause the cv's to wear out prematurely.
