Which control arms?
Old Nov 22, 2008 | 09:05 PM
0311sgt's Avatar
Try ROCK KRAWLER got these and love them
Old Nov 23, 2008 | 04:10 PM
Originally Posted by BlackNorthernJK
this is an excellent point...can you give us a better idea what your 'rough' ride is?
'rough ride' = the roads around VA Beach are far from heavenly...and bump after bump the front end feels 'squirelly'...sometimes jarring. I would think changing the angle that the front axel sits under the shocks and springs would fix some of this....meaning lower control arms to push the axel forward
which would also mean the front driveshaft would be spent because it is limited to say the least
Old Nov 23, 2008 | 04:49 PM
mkjeep's Avatar
I just put on Teraflex lowers today, night and day difference as far as the squirllyness, I highly recommend new lowers on a lift.
Old Dec 9, 2008 | 10:12 PM
Default currie control arms
X2 Currie
Old Dec 9, 2008 | 10:51 PM
Piginajeep's Avatar
X2 on fulltraction, they can take hit!
Old Dec 10, 2008 | 06:13 AM
TeraFlex's Avatar
Sponsoring Manufacturer
TeraFlex lower control arms have a clevite bushing on the frame side to quite things down. Then on the axle end you have a flex joint that is greasable/rebuildable and quiet. No metal on metal squeaks, from TeraFlex joints.
Old Dec 10, 2008 | 11:24 AM
mkjeep's Avatar
Or you can install them backwards and they still work
Old Dec 29, 2008 | 06:38 AM
VA_Rubi-Red's Avatar
Default Front control arms and drive shaft
Good info here. Thanks.
Is it necessary to upgrade the front drive shaft when adding more castor with front lower control arms?
Old Dec 29, 2008 | 08:33 AM
TeraFlex's Avatar
No it's not.
Old Dec 29, 2008 | 10:03 AM
Mark Doiron's Avatar
Been there, done that .. and they're still working great!
