which control arms?
Old Mar 23, 2009 | 03:26 PM
wayoflife's Avatar
JK-Forum Founder
Originally Posted by cvjoint
I got the Teraflex adjustable lowers and they are very heavy duty arms. The only thing I did not care for is the grease zerks they have to be mounted in a certain way so the control arms are parallel. So you have one side you have to take down to get to the grease zerk. I plan on just changing the grease zerk to a 90 degree one as soon as I find the right metric threads. If I buy more adjustable control arms they will definitely be Teraflex arms.
if you go to your parts store, you should be able to find a 90° narrow clearnace grease gun tip. rather than pushing the point of the tip onto the zerk, you slide it on. this is what i had been using anyway.
Old Mar 23, 2009 | 05:29 PM
rickl's Avatar
I HAVE TERAFLEX LOWERS HAVE BEEN GREAT,I USED A DIE GRINDER AND BURR TO CUT A SMALL RELEIF AND REPLACED THE GREASE ZERKS FOR BETTER ACCESS,APART FROM THAT SMALL TWEAK HAVE NO REGRETS WITH TERAFLEX LOWER ARMS,HAVE OVER 50,000KM ON THEM WITH NO ISSUES,THANX TERAFLEX
Old Mar 24, 2009 | 05:53 PM
Rubi 2sday's Avatar
Just got these in at the recommendation of David at Northridge.
Old Mar 24, 2009 | 05:57 PM
BaltChief's Avatar
No jam nut?.....what holds them in place?
Old Mar 24, 2009 | 06:38 PM
Rubi 2sday's Avatar
I'm no expert, but...
Once bolted in place the length can't change. These ride on bearings and use fine threads for adjustment. These came highly recommended, though I haven't seen any reviews, I figured I'd give them a shot. I'd love to hear from people that have experience with these.
Old Mar 24, 2009 | 06:54 PM
Beaver's Avatar
I put them on my Jeep, super heavy duty, work perfectly. highly recommend
Old Mar 24, 2009 | 07:21 PM
0311sgt's Avatar
Check out rock krawler high clearance adj lowers
http://www.rockkrawler.com/
Rock Krawler adjustable lower control arms are bent for improved ground clearance and cross over angles! They are made of solid alloy steel and come with our exclusive Abuse Proof Lifetime Warranty!
System Benefits:
-Improved ground clearance
-Better off-road performance
-Gain pinion angle/caster adjustability
-Abuse Proof Lifetime Warranty
i used these with their dana 30 lower control arm mounts for a perfect fit
Old Mar 24, 2009 | 08:45 PM
JK GABY's Avatar
Pictures can Tell more than a thousand wordsClick image for larger version
Old Mar 24, 2009 | 10:25 PM
high-octane's Avatar
I just put ft ultimates in my ride today. Drives like a different vehicle. I even let the girlfriend drive it now.
Old Mar 24, 2009 | 11:24 PM
chuck45's Avatar
I don't care for them as I'd prefer a flex joint (Johnny Joint) in at least one end. With no jamn nuts I think the threads will eventually wear more than if they were jamned.
I'd say go with Currie or Clayton.
