Control Arms Upgrade
Old May 3, 2016 | 07:31 AM
  #21
TheDirtman's Avatar
He is telling you how easy their new arms are to adjust. step 1 install them on the jeep. step 2 adjust to the needed length. step 3 remove the arms. step 4 put in your big shop vise and crank down the jam nuts. step 5 reinstall the arms. Not as easy as the synergy or off road evolution arms that have a single end double adjuster with lock nut.
Old May 3, 2016 | 08:55 AM
  #22
larry0071's Avatar
Not to mention that you now have to stock a garage full of grease guns to be able to service your Synergy balls with Synergy grease, RK grease for RK joints and RCV grease for your RCV shafts. I about hate the grease bullshit. How about using standard assed #2 grease like we've used for 200 years!?
Old May 3, 2016 | 09:29 AM
  #23
Chuck-The-Ripper's Avatar
I'm not saying I can't do it nor that I haven't done it, because I have multiple times. It's not really a big deal, but it is a pain in the ass.
What you're failing to mention is the lack of a wrench flat or anyway to hold the joint in place as you tighten the jam nut. What you describe is like explaining how to replace a clutch is easy. Step 1. Remove transmission step 2. Remove clutch step 3. Replace clutch step 4. Replace transmission. Sure, it's not brain surgery, but it is frustrating.
Old May 3, 2016 | 10:05 AM
  #24
jedg's Avatar
Vet Army
Originally Posted by Chuck-The-Ripper
I'm not saying I can't do it nor that I haven't done it, because I have multiple times. It's not really a big deal, but it is a pain in the ass. What you're failing to mention is the lack of a wrench flat or anyway to hold the joint in place as you tighten the jam nut. What you describe is like explaining how to replace a clutch is easy. Step 1. Remove transmission step 2. Remove clutch step 3. Replace clutch step 4. Replace transmission. Sure, it's not brain surgery, but it is frustrating.
Ummm. He's being sarcastic.
Old May 3, 2016 | 10:14 AM
  #25
DunnyBunny's Avatar
JK-Forum Ambassador
He mentioned it when he said put it in your bench vice. 2 work better or a setup like kjeeper10 has done. But really it isn't that hard to get the joints straight and everything tightened. Again 2 vices is best as you can put both ends in a vice and wrench away.
I was thinking the same as you with the wrench flat if it was on the tube. Would make it easy to do it on the vehicle itself cutting down some time of crawling in and out from under the jeep.
Old May 3, 2016 | 03:01 PM
  #26
kjeeper10's Avatar
Vet Army
The axle side fork shouldnt be as hard to keep center. Now you are left with the frame side joints.
Old May 3, 2016 | 07:28 PM
  #27
Well don't I look like quite the fool.
Old May 4, 2016 | 05:35 AM
  #28
Morris4x4Center's Avatar
Sponsoring Vendor
Originally Posted by Lally17
Do not order from Morris 4x4!!!
I ordered a set of front and rear lowers and uppers, and they sent me two sets of front lowers and not a set of rear lowers. Needless to say my jeep is up on axle stands while I figure out a way to fix Morris 4x4's issue. They said they will not pay for the return shipping on a part that they messed up on... Great customer service ...NOT
Hey Lally, please shoot me a message so I can look into what happened with your order.
-Chris
