Converting The E-Disco To Manual
Old Jan 28, 2011 | 08:19 PM
ronjenx's Avatar
Default Converting The E-Disco To Manual
Here are some pics of how the conversion to manual control was done.
Go here to review how it works in its stock configuration:
https://www.jk-forum.com/forums/show...rtbar%29-Study.
Old Jan 28, 2011 | 08:20 PM
ronjenx's Avatar
Here is a clip of the progress on the lever.
It's a mock-up using an XJ console I had in the barn. I won't be installing the sway bar/lever into my JK until the electronic one fails.
The piece of track hanging from the bar simulates the bar being loaded from the Jeep being on uneven ground. As the Jeep moves, the bar will unload, and release. The lever will remain in the release position from being over-center.
When moved to the reconnect position, the lever will be free until the splines on the bar line up. It will be obvious when the bar reconnects, as the lever will be held in the forward position.
Watch the lever as the bar reconnects. You will see it move forward.
Old Jan 28, 2011 | 08:31 PM
zeppo's Avatar
Glorious real world exploded view and write-up as always. Looking forward to seeing the finished product.
Old Jan 28, 2011 | 08:36 PM
NH-JK's Avatar
Looking good! Nice job.
Old Jan 29, 2011 | 03:55 AM
bigljking's Avatar
Good ole Maine ingenuity : )
Old Mar 24, 2011 | 04:45 PM
ronjenx's Avatar
See post #2 for a clip of the lever in action. Let me know if the lighting is adequate, and how it plays.
Old Mar 24, 2011 | 05:02 PM
JCKnauer22's Avatar
looks good! i'll definitely be going this route if/when mine ever dies. amazing work
Old Mar 24, 2011 | 05:57 PM
B09RUBI's Avatar
Same here when my electrical is all done I will do this!
Old May 4, 2011 | 12:54 PM
rinkishJK's Avatar
Awesome work man!!!!!
Old May 11, 2011 | 06:48 AM
jeffrocc's Avatar
no if about it, your e disco WILL fail, its just a matter of time and environment. If you live in the desert, long time, anywhere water hits the front of your jeep, failure is imminent. chrysler should be hammered about this, its an unbelievable engineering screw up.
