Converting The E-Disco To Manual
Old Apr 9, 2012 | 03:44 PM
mbernardo's Avatar
What did you do to the plug? Did you cut it off? I do not want to have a short circuits like I did in last sway bar that was swapped in warranty.
Thank you.
Old Apr 9, 2012 | 03:57 PM
ronjenx's Avatar
Thank you.
I haven't done anything with the plug, as the electronic sway bar has not failed yet.
Old Apr 9, 2012 | 04:03 PM
BKGM Jeepers's Avatar
I'm confused. If you put in a manual override it should enable you to engage and disengage at will. Does removing the electrical connection throw any lights on your dash, like BAS or ESC?
I've run my e-disconnect for 4 years without failure and I wheel mine more than most people. however, I have manual disconnects on my e-swaybar because I cannot stand the 18mph re-engagement.
I'd like to see finished pics and how it works, as well as how everything else works for ya. Good luck!
Old Apr 9, 2012 | 04:12 PM
ronjenx's Avatar
Originally Posted by BKGM Jeepers
I'm confused. Does removing the electrical connection throw any lights on your dash, like BAS or ESC?
A ProCal will keep the e-disco light off after I do the conversion. No other lights will come on due to the conversion.
I will certainly post pics of the installation when I do it.
Old Jul 6, 2012 | 12:05 PM
jkrubcon's Avatar
Can you provide a source for the cable. I realize it's just a simple cable, just saying
Old Jul 6, 2012 | 12:41 PM
ronjenx's Avatar
Aircraft Spruce has them. It's a push-pull throttle cable.
Old Nov 1, 2012 | 12:46 AM
Maritime's Avatar
Nice thread. I'll give it a good read on my days off.
Old Nov 1, 2012 | 02:11 AM
Sahara_Maverick's Avatar
Awesome! I recently got a Rubicon sway bar for my Sahara and was evaluating whether connect it electrically or using that mechanical disconnect that replaces the motor. This is a much better solution than both. Thanks for sharing.
I could not see any link to the movie on your second post, at least on my phone app. Is it possible to send the URL?
Old Nov 1, 2012 | 04:03 AM
Nbjeep's Avatar
Very nice. Good job!
