Cooper ST Maxx
Old Aug 15, 2015 | 06:52 PM
Grognard's Avatar
Default Cooper ST Maxx
Thinking of putting Cooper ST Maxx on my rig. Anyone with experience with this tire?
Old Aug 15, 2015 | 07:46 PM
WarPig512's Avatar
Yep. 35's with 16k on them so far and they're holding up great. You won't be disappointed
Old Aug 15, 2015 | 10:18 PM
bluebear's Avatar
Did a lot of research before deciding on them...no regrets
Old Aug 18, 2015 | 06:01 PM
CopyGuy's Avatar
Have 40k miles on my 255/80/17 ST Maxx tires and still have approx 2/3s tread left. They are the best AT tire I have ever owned. The only thing I regret is not getting them in 35s.
Old Aug 28, 2015 | 11:33 AM
JK703's Avatar
Hoping you see this reply. Do you have a lift of any sort on yours? Wheel spacers? Stock wheels? I have a JKU Sport with 17" wheels. Looking at putting on Rubicon shocks, 1.25" spacers (cosmetics), and then these exact tires.
Old Aug 28, 2015 | 03:14 PM
stangmike1's Avatar
I had them for a week not bad.
Ended up switching to Toyo RTs best tires I had so far same price point and 45K mile warranty which coopers don't have.
Old Aug 28, 2015 | 05:58 PM
CopyGuy's Avatar
I do have the AEV 2.5 DS lift, my wheels are factory 17" with no spacers. You should be just fine with what your planning on doing. I know you said you were adding spacers for looks, but FWIW you wont really need to use them because the tire at 255/80/17 is the same width as the factory tires and is only about an inch taller. If you disconnect and flex out fully you might rub a little, but I'd say you should be good to go with your plans.
Good luck, and share a pic or 2 when you get it done.
Old Aug 28, 2015 | 10:32 PM
Grognard's Avatar
I do not have a lift yet. Should be delivered Monday and hopefully installed next week. I did put my tires on as someone wanted to buy by Rubi take offs. So I am stock on 35s with flat fenders for a bit.
I did not end up with the ST Maxx as it turns out. Discount Tire down here does not carry them. I ended up with Dick Cepek Extreme Country, which is made by Cooper and is another branding of the ST Pro as it turns out. So still a cooper tire.
I have procomp La Paz 29 wheels, 4.5" backspacing, 16" wheels. Don't need spacers as not rubbing.
ID:	623028Click image for larger version
