Corner armor recomendation that will accomodate stock tail lights
Old Apr 2, 2015 | 07:51 AM
Learo2000GT's Avatar
Default Corner armor recomendation that will accomodate stock tail lights
Y buddy ground guided me into a tree this weekend and I bashed in the rear tail light and dented the corner a bit. I was looking for rear tail armor that accommodates stock tails. I have a set of blacked out tails I wanted to put on. I was thinking of going with the bushwhacker tail gaurd. I know it will not provide armored duties but I have bushwhacker flares abd am not a hardcore wheeler and don't plan on backing into any more trees. I would like to go with a true ar our corner but they all look to be in 600 range and reguires circle leds. Thank u in advance Doug.
Old Apr 2, 2015 | 07:59 AM
TreyJK's Avatar
I think Warrior makes something similar to BushWhacker. Oh and AEV is also similar in looks but constructed of metal.
Old Apr 2, 2015 | 11:36 AM
Thank you. I will check those out.
Old Apr 2, 2015 | 12:58 PM
evoviii2jk's Avatar
I have the AEV ones. They run about 350 I think. They are really stout and look pretty good in my opinion
Old Apr 2, 2015 | 02:31 PM
Invest2m4's Avatar
I've heard this too many times to count. When I do, I tell the person to get full corner armor and steel fenders. They don't and then sometime not too much later, they take a tree to the side and jack everything up. Then they buy it.
Old Apr 3, 2015 | 03:39 AM
Kojack's Avatar
I am running the bushwacker corners this year. I won't be hitting stuff hard, maybe will rub the corner on something but no hard hits. So these will be fine.
Old Apr 3, 2015 | 05:00 AM
Biginboca's Avatar
Are the bushwhacker corners plastic like the flares?
The AEV corners are steel?
Old Apr 3, 2015 | 06:50 AM
JE8154's Avatar
Aev corners are steel. You're better off getting rid of the stock tail lights if you wheel in an area where you could back into a tree.
Old Apr 3, 2015 | 09:43 AM
JK505's Avatar
I'm the exact same boat, smashed a tail light and slapped some band aids on it for now. Ordering the Evo corners today with flush tail lights. Get it done and never worry about it again.
