Correct P.S.I.
I am running 315/70/17 Pro-Comp Extreme M/T's on 17x9 Pro-Comp 7189 Wheels. I was wondering if anyone is running this set up or close to it, If so what Tire PSI are you running for daily driving? Any input would be appreciated...
C:\Documents and Settings\Marc.catalina\My Documents\Cassidy\Cassidy 527.jpg
Before you go and do the chalk test think about it for a minute. The tire is part of the suspension. Your Jeep has been engineered and tested to perform at its optimal levels with the tires at 35 psi. While a chalk testonly proves you full foot print at lower pressures, it does NOT prove anything else. Anyone who watches NASCAR knows that a differance of ony 1/4 pound makes the difference between turning and not turning. While this is an extreme example, I think you get the point. Lowereing your tire pressure below 35 psi will give a softer ride because it ultimately lowers your spring rate. Lower spring rate means more body roll in corners, more body roll means ESP involvment while drivng everyday. Remember a few years ago in So Cal. ALL the tire failures?? LOW TIRE PRESSURE was the cause of 99% of those accidents. So just keep them at 35 psi. and keep the chalk in the classroom where it belongs.
Doing the chalk test is a good idea to try and maximize tire life. Anything over 30PSI is pretty road-safe.
-E
