CTM or Yukon U-joints or ?
Old Feb 9, 2011 | 09:47 AM
toymaster's Avatar
Default CTM or Yukon U-joints or ?
I have superior evolution super alloy axles, which U-joint is a good match to the axle's strength? I know the CTM are top-of-the line but $250/ea da*n. Anybody out there running the CTMs, Yukons, or other top-end joint have any comments??
I am debating on doing the parts list below and am unsure of the best matched u-joint. (not asking opinions on anything except u-joints)
Details Name Unit Price Quantity Total Select
DYN-PROSTEER Dynatrac ProSteer JK Ball Joints $594.95
REID-JK001L Reid JK Steering Knuckle Left Side (JK001L) $259.99
REID-JK001R Reid JK Steering Knuckle Right Side (JK001R) $259.99
CE-JK-9701 Currie JK Currectlync Heavy Duty Tie Rod & Drag Link System (JK-9701) $799.90
Sub Total: $1914.83
Old Feb 9, 2011 | 10:05 AM
Dynatrac's Avatar
Sponsoring Manufacturer
The best of your choices is CTM. It is the only joint that can be used on a DD. The other joints are not recommended in rig that doesn't have locking front hubs. The CTMs have a bushing inside to allow road use. The others just use a coating on the inside of the cap. You'll need to be sure you keep the CTMs greased well.
Old Feb 9, 2011 | 10:07 AM
Northridge4x4's Avatar
Sponsoring Vendor
your choice is really CTM u-joints or RCV shafts.
I have had both and they are great
If you already have the axles go with the CTM's
David
Old Feb 9, 2011 | 10:23 AM
GCM 2's Avatar
David
x2, everything David said. CTM's are a big ticket expense item, but worth it for the reasons David listed. The RCV's are a whole lot more expensive, however, with a no questions asked, "you break it, we replace it" warranty, the one time purchase is pretty reasonable for the peace of mind.
Old Feb 9, 2011 | 10:36 AM
toymaster's Avatar
The list price of the evolution axles are really close to the RCV but I got the superior evo axles for under $300 for both last year from a shop going out of business. I was just wondering if there was anything between the CTMs and a spicer u-joint in quality.
Also, if the cheaper/weaker u-joint broke what would be the chances of damaging these high dollar axles. From my past experience with dana axles and spicer joints you had about a 30% chance of axle damage.
Old Feb 9, 2011 | 10:37 AM
Dynatrac's Avatar
Don't completely agree here. A set of EVO shafts and CTMs usually exceed what you'd pay for RCVs. RCVs are usually more expensive than import shafts and CTMs.
Old Feb 9, 2011 | 10:39 AM
Dynatrac's Avatar
Since the CTM u-joint was revised a couple of years ago there haven't been any failures (IIRC). The shafts always go first.
