Wheel manufacturer says, "Not enough offset".... is that true?
Old Feb 9, 2011 | 06:27 AM
George F.'s Avatar
Default Wheel manufacturer says, "Not enough offset".... is that true?
Im looking at a wheel with the following specs:
Size: 17'' x 8''
Bolt Circle: 5 x 5.0''
Rear Spacing: 4-1/2''
Offset: 0mm
This is exactly the wheel spec I have read that many others are running.... what could possibly be wrong with the fitment of it?
Old Feb 9, 2011 | 06:45 AM
OoPEZoO's Avatar
Nothing.....thats perfect.
Its the exact same size wheel size I'm running with my KM's. What company are to talking with?
Old Feb 9, 2011 | 07:07 AM
George F.'s Avatar
I thought so too- interestingly enough, its American Racing that claimed this (two separate techs) the second of which admitted it would fit "but only with at least 2" of lift".
Survey SAYS?!???
buzzzzzzz
Old Feb 9, 2011 | 09:10 AM
OoPEZoO's Avatar
Yeah.....thats BS. Its really the other way around. If you put on a lift you would need to add the wheels (or spacers) to get the needed backspacing to keep from rubbing, but strictly adding the wheels to a otherwise stock Jeep won't give you any issues at all.
Old Feb 9, 2011 | 10:48 AM
tslewisz's Avatar
Size: 17'' x 8''
Offset: 0mm
It's absolutely fine.
