Currie brake line leak
Has anyone installed the Currie extended braided steel brake lines and noticed a minor leak?
I installed them today and the pass side buttoned up perfect. The drives side bracket did not allow the line to seat properly with the hard-line and I had to remove the hard-line from where it clips in in the engine bay...I then noticed that it was leaking when bleeding the brakes. I re-installed in (cleaning the threads with brake-kleen) and it seems to have fixed it. I have driven a fair bit today with it and the pedal pressure is good however there is still some moisture on the threads where the hard-line attaches to the currie brake-line. I don't know what else I can do....
