currie control arms
Old Oct 5, 2012 | 10:51 AM
hneiper's Avatar
Default currie control arms
Well, looks like I'll be pulling the trigger on a set of currie control arms (all 8). Replacing the skyjacker and stock arms that came with the jeep. I've already replaced all my control arm bolts with 9/16 bolts and was wondering what size bolts these arms use? Also, any one have any issues/tips with installation as I will be doing this myself.
Worth mentioning too that the front lower have cam bolts. I will be welding on some steel and drilling new holes. Also, the front upper mounts frame side the holes are wallowed a bit so will be doing the same there.
Cheers,
Harold
Last edited by hneiper; Oct 5, 2012 at 10:56 AM. Reason: left out some relevant info
Old Oct 5, 2012 | 10:53 AM
wayoflife's Avatar
JK-Forum Founder
you should just be able to use your factory grade 10.9 bolts. install is simple and can practically be done with your jeep on the ground. just do them one at a time.
Old Oct 5, 2012 | 10:58 AM
hneiper's Avatar
don't think i have them anymore
yeah, i've pulled mine off before while on the ground. so from that front i should be good. kind of a hodge podge of bolts now, couple of them are still stock because they run in the frame at the rear but the others i've replaced.
Old Oct 5, 2012 | 01:19 PM
hneiper's Avatar
Made a quick call to Currie and confirmed what i have will work.
Make a quick jump over to NR4x4 and ordered the 8 arm set Can't wait to install this.
