Cut Coils Shorter
Cutting coils doesnt hurt anything the problem is the top coils are flattened to dispurse the springs compression evenly over the surface of contact and when you cut them the coils have a tendamcy to want to bow out a little vs straight compression. The cut coil is no longer a flat surface so instead of sitting in the pocket and pressing semi evenly it compresses and pushes out a smidge...
So as suggested see about vendor options first....
The front coils are progressive weight springs so cutting the spring will actually affect the way they perform. As someone mentioned, your best option is to contact Rock Krawler or swap with someone looking for more lift.
