cylinder 1 misfire code HELP
Old Jun 24, 2016 | 07:48 PM
America$uckyeah's Avatar
Default cylinder 1 misfire code HELP
so went to drive my jeep this afternoon and it sounded really weird. plugged in my super chips and boom, get a cylinder 1 misfire code (PO301). gonna take it to the shop tomorrow to hopefully get it fixed quick. Do you guys know what are the most likely causes? hoping maybe just needs to plugs and wires.
Old Jun 25, 2016 | 02:09 AM
sa29560's Avatar
Didn't pull the plug to take a look?
That's one of the easiest to get to as well, pop it out and look for irregularities.
Old Jun 25, 2016 | 03:13 AM
ronjenx's Avatar
Quick fix is possible, but very unlikely.
Misfire codes can be caused by more things than any other code.
Old Jun 25, 2016 | 05:44 AM
jtphoto JK's Avatar
Check plug first. I could be simply a failed plug or bad plug wire.
Old Jun 25, 2016 | 07:15 AM
Yea I'm going to replace the plugs and wires today, I'm about to hit 100k so it's needed anyway. If that don't work I'm gonna have to put it in the shop
Old Jun 25, 2016 | 11:55 AM
Anybody know the size of the ignition coil bolts that hold it to the bracket? Need to buy a socket for it
Old Jun 26, 2016 | 02:12 AM
DJ1's Avatar
DJ1
Former Member
There was a recent thread on here with another member going through the exact same thing. Do a quick search. The culprit was a bad spark plug which was actually the last thing he checked after replacing the wires, etc. You gotta pull the plug and inspect it.
search "misfire" or "spark plug* ...should come up
Old Jun 26, 2016 | 11:27 AM
Welp I replaced the ignition cool and now it works great, the coil is what went bad
Old Jun 26, 2016 | 01:32 PM
jtphoto JK's Avatar
Did you change plugs as well?
Old Jun 26, 2016 | 06:44 PM
Yes I did
