D Rings ARB Bumper
What are you all using for the D rings on the ARB front bumper?
I put some Warns on there and they are loose as heck.
The hole is about 1 1/8" across and I can't find a good size ring to go in there nicely.
They hang so low that I don't want to put a HUGE ring on them.
Thoughts?
Thoughts?
do you have a Tractor Supply store around you anywhere? If so, they've got a few different sizes that may work....they didn't have the ones I needed though, I had to order mine from Quadratec. I needed some with a 5/8" pin, got em for $20 through Quadratec. What you may have to do is get something like a 3/4" and fill in the gap with some ballcock shank washers like is mentioned HERE
if i remember correctly, the warn shackles have a pin that measures 3/4" in diameter and the holes on the ARB bumper do in fact measuer 7/8" in diameter. so you know, a lot of 3/4" shackles have pins that measuer 7/8". in any case, the ball cock shank washers shown in the link will fix your rattling problem
