D31A Optima Yellow top Battery
Old Jan 11, 2008 | 08:24 AM
o|||||||o EDMONTONTRADER's Avatar
Default D31A Optima Yellow top Battery
I am at Work otherwise I would just go and measure..........does anyone know if a D31A Optima Yellow top Battery will fit in a JK.
The measurements are.......
Specifications:
• BCI Group Size: 31 (SAE Post)
• Voltage: 12
• Cold Cranking Amps @ 0 F: 900
• Cranking Amps @ 32 F: 1125
• Reserve Capacity Minutes: 155
• Amp Hour (20 Hour Rate): 75
• Weight: 63 Lbs
Dimensions (Maximum Overall):
• Length: 12 13/16"
• Width: 6 1/2"
• Height: 9 3/8"
Old Jan 11, 2008 | 08:27 AM
Here is a pic............
Old Jan 11, 2008 | 08:42 AM
i have a yellow top optima in my JK
i picked it up at Advance Auto Parts, looks bigger then the one you have pictured
Old Jan 11, 2008 | 08:51 AM
do you know the model you have?
Old Jan 11, 2008 | 11:30 AM
releve's Avatar
same here, I have the D34 in my JK fits like a glove.
Old Jan 11, 2008 | 06:50 PM
JulietKilo's Avatar
The D31A is larger then the D34.
The D31A has more power, more longevity, more CCA and is a few inches larger then the D34.
Go here for specs. http://www.1st-optima-batteries.com/yellow_top_battery.asp
So to answer the original posters question; if there are a few more inches on each side of the jeeps mount i may fit with some small modification or movement of electicals, hoses, etc.
Last edited by Robar; Jan 11, 2008 at 06:52 PM. Reason: Please dont post direct non sponsor links.
Old Jan 12, 2008 | 06:35 AM
Ben Hedrick's Avatar
I have an Optima Blue Top in my JK and it fits great. The Blue Top is nice because it has extra posts for lights, winches and other items. Plus it is a Marine deep cell and will run the lights and winches longer. I got mine at Discount Auto for $179.
Old Jan 12, 2008 | 08:25 AM
bly109's Avatar
bump
Will this fit? Or do I need to go out in the cold tonight and measure?
Old Jan 12, 2008 | 09:01 AM
Originally Posted by bly109
bump
We still don't know......... lol
Old Jan 12, 2008 | 10:09 AM
LOFTY's Avatar
Comes fitted as standard on Euro Diesel, was a surprise when i looked under the bonnet.
