D31A Optima Yellow top Battery
It's not that easy to check as the thing is almost completely wrapped up in it's own little sleeping bag. It's snowing at the moment so I will have a look in the morning.
I'm not that impressed with the Optima. Over the last month or so, cold mornings seem to be giving it a hard time. My 4.0L XJ that is parked in the same garage overnight has an Odyssey PC1200MJT and it copes with the cold far better.
I have an AccuMate Pro charger that is designed for Odyssey and Optima batteries. The yellow Optima recovers well after being plugged in. I suppose cranking the diesel motor, short 30 to 40 minute journeys and overnight temperatures sometimes at 14F (-10 degrees Celsius) take their toll. If it packs up and doesn't get replaced under warranty, I will get an Odyssey to replace it.
I measured last night and it seems like it will be about a 1/2" too long. Id have to pull the stock battery out to really get a good measurement of the tray and to see if it could be easily trimmed to fit the larger optima. I might do that this week when I install my winch.
Ben: Is your blue top a D34M or D31M?
Here's a picture of the battery in my diesel JK. The Optima part number sticker is obscured by the battery jacket and I would have to take the battery out to read it. The battery is roughly 320mm long and 165mm wide. Again, I would have to take the battery out to get accurate dimensions and a measurement for the height. Hope this helps.
ok just looked in parts catalogue it is a 31d
that battery is part #0472747AC
hold down bracket as seen above 55397393AB
but the tricky part it may require a different tray on the fender (can the poster of the pic above take a shot from the driver side looking toward the battery and post?
and cover or wrap around is 055397393ab
