Dana 30 build
Originally Posted by Dynatrac
I definitely recommend the Truetracs. They aren't a locker but they're still very good. They won't be as harsh on your 30 components as a locker, but depending on how you use your rig, they may or may not cause more damage. Confusing huh?
If how and where you wheel doesn't really require a locker you'll be fine. But if most places you wheel really require a locker, and you have a TT, you may have to work your rig much harder which increases your chance of damage. I hope that made sense
As for the axle shafts vs u-joints:
With all but the best axle shafts, much of the time when you break a u-joint you usually do damage to the shaft yokes (ears). If you're going to try and use the u-joint as a fuse, be sure get a good DOMESTIC (no import) 4340 shaft. More money? Sure but you have a much better chance of having the axle survive a u-joint failure.
Question. I live in east Texas. There's no rocks to climb. We trail ride in dirt, mudd and the occasional washout to climb up. For me I see no point in a locker up front but I'm putting one in the rear. I don't think that any of the things that I will be really doing will put to much stress on it will it?
As long as you rarely lift a front tire you should be fine. You'll notice a huge improvement with TTs front and rear.
P.S. I called Screamin Lizard Customs, that who I am getting to do my gears, and I told I wanted a Detroit truetrac instead of a locker up front and it save me about $400!!!!!!
