dana 30 question
Old Dec 12, 2008 | 01:20 PM
jkwranglerscott's Avatar
Default dana 30 question
ok so im new to the forum and I want to lift my 2007 2 door x and put it on 37's the only problem is i have a dana 30 in the front I dont do too much wheeling and when i do its not really extreme no rock crawling theres nothing good around here but my question is how bad would it be to put 37's on the dana 30 with the type of driving i do which is mainly street and alittle offroad such as the beach and sandpits. Thanks for the help.
Old Dec 13, 2008 | 04:10 AM
WV99XJ's Avatar
Go for it and upgrade if you break it.
Old Dec 14, 2008 | 05:26 AM
Originally Posted by N2rock
Buddy of mine. He's running 37's on a D30 front, and was in a competition.
Run #1- D30 stock axle shafts. Resulted in broken axle shaft
http://www.youtube.com/watch?v=MWDgy...e=channel_page
Run #2- swapped out the broken shaft for Chromoly shafts
http://www.youtube.com/watch?v=e7K8S...e=channel_page
Obviously you're not going to punish your rig the way he did. So a D30 will likely be ok. But if you really want to be safe and not worry about it when you go wheeling, change the shafts to chromoly shafts.
Of course, anything can break
thanks for the help on that any idea where i could order them from I did a quick search but everything I found was for tj's not the jk's
