Dana 60s
Old Oct 14, 2018 | 08:52 PM
BlackSheep2012JKU's Avatar
Default Dana 60s
Im wanting to put Dana 60 under the front and rear of my jeep. Im looking to do a junkyard swap and didn’t know if there was a certain vehicle to Pull the axles from for my ‘12 JKU. Hoping someone might have some advice?
Old Oct 16, 2018 | 07:32 AM
MountainWhisky's Avatar
5 Year Member
IIRC the Ram 2500 from the late 90s, early 2000s with the gas V8s have them both front and rear. I think the Ram 3500 from the same time period also had them in the front. I'm assuming you're a pretty good fabricator....? That isn't an easy swap.
Old Oct 16, 2018 | 09:17 AM
hivoltagedriver's Avatar
Not sure on the rear 60, but my front is out of a 2006 F350SD. We used the Artec kit, and I matched the reluctor wheels on my 14-bolt in the rear so all of my ABS sensors still function. You WILL need all 4 functioning, even if you run them off of two wheels. The 14b or Ford Sterling are both 10.5" ring gears, and stronger than the 60. I sold my Rubicon axles, and ended up with around $3000 in my axle build. 5.13s, ARBs, Artec kits, new brakes, seals, bearings, U-joints, etc...
Old Oct 17, 2018 | 08:03 AM
BoraBora's Avatar
Hope you're aware of everything involved (wheels, driveshafts, brakes, etc.). Read this first: https://www.jkowners.com/forum/modif...-ton-swap.html
Here's a guide from Artec: JK 1 Ton Swaps
Ideally you want a 2005+ Superduty front, with 14b in the rear. Sterling 10.5's won't play nice with the factory gas tank skid on JKU's, so you'll need a fuel cell. Good thread: https://www.jkowners.com/forum/modif...xle-bible.html
Check out some of the axle bibles on Pirate: https://www.pirate4x4.com/forum/jeep...ps-thread.html
