Dashboard is Freaking Out*
I don't know if this is the right section. But all my electrical is "freaking out". When i drive the car the AC, ABS light, Traction Control, Door locks, Emergency Break Light, Speakers die and MPH gauge goes to 0. This goes on and off erratically through out my drive. Any Idea what is causing this?
I must add i pressure cleaned my car and under carriage and it started doing this after. I checked all fuses and none are blown.
It is a 2012 Unlimited.
Any help is appreciated.
Thanks!
Thanks!
It's your TIPM, call the dealer, yes those guys, and tell them what is going on. It happens, but its an easy fix, expect to pay 500+ to get it fixed though... the part isn't cheap, but at least it's a quick job.
Actually the part is half that price at most and takes about 15 to pull the old one out, put the new one in and do the key dance to program it. I'd try and order one offline somewhere and do it yourself cause dealers are completely ripping you off by putting these in and charging you hours of labor for 15 mins of work.
I've seen this, too ^^^^^^^^^^^^^^. Have your battery checked. FYI: I checked on TIPMs for my '07 and they were on national backorder three weeks ago. Mine didn't have the problems you describe exactly, but I pulled it, disconnected all of the electrical connections and cleaned them (none looked dirty) with brake cleaner, pushed in all the fuses and relays, put it all back together and went on a couple thousand mile trip without further problems. This is the second time it's acted up in a couple years, and the second time this "repair" seemed to work.
My 2012 JKUR was doing a similar thing. However it also would not start. I would turn the key and the lights on the dash would randomly flash on and off. mph and tach would jump around.
Mine would not start though. I charged my battery even though it had never been sluggish starting. I could not get it to take a charge at all.
Got a new battery and it worked great. No issues since.
