daystar 1 3/4 problem
Old Aug 20, 2013 | 07:58 PM
Yose's Avatar
so alignment should fix that? they must not know what they are doing at my dealership
Old Aug 20, 2013 | 08:16 PM
karls's Avatar
If your steering wheel is off by enough to come in contact like that then you should be getting a code on the dash with some lights to let you know you've got a problem. Additionally you should notice you can turn the wheel further one way than the other.
Sent from my DROID4 using Tapatalk 4
Old Aug 20, 2013 | 08:27 PM
Yose's Avatar
no code. it is centered.
Old Aug 20, 2013 | 08:37 PM
Woody's Avatar
Vet Army
Was it just me or did the sway bar links look a little short there by causing the interference? sway bar is ideally horizontal + or - 5 degrees
Old Aug 21, 2013 | 05:49 AM
Yose's Avatar
I checked and it turns left more than it can turn right. So I better bring it back to the dealership and have them align it again. Idiots
Old Aug 21, 2013 | 06:28 AM
2012_2dr's Avatar
Need longer sway bar links
Old Aug 21, 2013 | 09:18 AM
Ncb's Avatar
Ncb
Good luck.
