Daystar help
Old Aug 19, 2011 | 06:10 AM
glocksrfun's Avatar
Default Daystar help
I got a daystar for free. Went to install it and it's not fitting right cause it's hitting this thing. What is this? I have the nav, is this the gps anttena?
Old Aug 19, 2011 | 06:43 AM
centerfieldr162's Avatar
Mine doesn't hit anything.. Hmm.. Make sure the front of the panel is on first then try to pop the two back ends down.
Old Aug 19, 2011 | 06:50 AM
glocksrfun's Avatar
Does yours have this same anntena looking thing?
Old Aug 19, 2011 | 06:52 AM
emoody007's Avatar
That's the Antenna. It should come off and attatch to the Daystar panel with the screws. if you look at your daystar panel you'll see a place to screw the unit to the panel. Hope that helps.
Old Aug 19, 2011 | 06:53 AM
No, but it does have a little cluster of wires that were kinda hard to fit the panel over. My Jeep is at the shop otherwise I'd run outside and take some pictures. Have you tried to push the back ends of the panel in, even with the panel hitting this? If so, is it noticeable that it's hitting it?
I don't have that probably because I don't have a nav unit
Old Aug 19, 2011 | 06:55 AM
glocksrfun's Avatar
I did. I didn't put the metal clips on. Once I get to about an inch left to go down, it starts to hit. When I push the back all the way down, there is a little bulge where the ant. is. I needed a good amount of pressure to keep the back down. Not sure if the metal clips would hold.
Old Aug 19, 2011 | 06:57 AM
glocksrfun's Avatar
The one you are talking about is still attached to the dash panel in the pic. I just took off the panel with that ant. still attached so I could take a pic of this other anttena.
Old Aug 19, 2011 | 07:02 AM
The metal clips will probably hold. Do you see a place to attach this to the new dash panel like the other poster was saying? The only thing I know that you attach to the new dash panel is the previously existing wires on the old dash panel.
Maybe someone who has this antenna thing can chime in since I don't know
Old Aug 19, 2011 | 07:08 AM
glocksrfun's Avatar
Yes. The first time I went to intasll, I moved the compass antenna to the daystar. That's when it didn't go down. After messing with it a little, I saw it catching on the nav anttenna. I did a test fit before I moved the metal clips from stock to daystar. The bulge was very noticable and it took a lot of pressure to hold down. I didn't like it. I aborted mission at that point and wanted to do some research before I go any further.
I just got an email from someone at daystar. Very quick response, he said he hadn't seen this issue, he's going to talk to some people.
Old Aug 19, 2011 | 07:10 AM
Glad they got back to you that quick. Hope you get everything figured out
