Daystar switch panel and 6-speed
Old Apr 24, 2011 | 07:46 PM
Hulk's Avatar
I plan on switching to the s.P.o.d (it kept editing it) later and ditch the daystar panel
Old Apr 24, 2011 | 08:05 PM
Hulk's Avatar
Originally Posted by saravonshep
What is this, s.p.o.d Dont think ive heard of this.
It's very nice. 4x4s.p.o.d.com minus the .
Old Apr 24, 2011 | 08:59 PM
raidue's Avatar
Interesting.
I was looking at the pillar switch pod. Didn't see the write-up for putting it above the rear view mirror. That actually sounds like a brilliant idea. Very easy access and visibility.
Was it a daystar that mounted up top?
Old Apr 24, 2011 | 09:17 PM
jkinportland's Avatar
The Daystar and my 6 speed did not mix. If someone wants it they can have my Daystar panel. PM me if you want it.
Old Apr 24, 2011 | 10:54 PM
bobbyspaghetti's Avatar
Default Meh
Unless you are completely against drilling holes in your jeep just mount them somewhere else.
KC Windshield mount Slimlite switch
ARB under hood mount compressor
This opens up many possibilities and the price is attractive right around the $00.00 price point. However if your not into putting holes in your jeep it's not greatest.
Old Apr 25, 2011 | 06:15 AM
raidue's Avatar
I don't mind putting some holes in. I will be up to 3 switches now (once I add my ARB compressor) so the switch panel kinda made sense them they can share a common power amongst them too.
Old Apr 25, 2011 | 05:15 PM
Planman44's Avatar
I have the daystar switches with a 6 speed and havent had any problems. Nothing hits or interferes. I like it
Old Apr 26, 2011 | 05:06 PM
KenB1010's Avatar
I had this problem in Moab. Shifting into 1st gear the shift boot would hit my locker switches and turn them off. I was going to change out the switches to a flatter switch and WOLette told me to just push the shift boot down to clear the switches and put a wire tie on to hold it in place. Gotta love a simple solution.
Old Apr 26, 2011 | 10:42 PM
raidue's Avatar
Yeah a simple fix is always nice.
I've seen some pics where they remove the factory rubber boot from the shifter and put a leatherish one on in place that does stick out as far. That would probably be an easy fix too.
Old Apr 28, 2011 | 06:29 AM
raidue's Avatar
Can someone post a link of the switch panel install above the rear view mirror. Would like to see that.
