Death Wobble
Old Dec 24, 2010 | 04:50 AM
Michael's Avatar
Default Death Wobble
I have an 08 X 2door. I have retorqed everything under it, put a new taraflex steering shock and still have'nt fixed my wobble. And the worse thing is I'm running 29 in dayton timberlines. I can only imagine what would happen if I put bigger tires on this thing. Can yall give me anymore ideals of stuff to look for?
Old Dec 24, 2010 | 04:57 AM
CJ7nvrstk's Avatar
Vet Army
I think one of the most overlooked problems is tires. Everytime I have had DW, it has been d/t either crappy balancing by 4WP or tires chunking and then being out of balance.
Of course, make sure everything is tight up front. You really shouldn't be having those problems with 29's. My bet would be it's the tires.
Old Dec 24, 2010 | 05:10 AM
Michael's Avatar
The paint started coming off of my rims about 10'000 miles back and the dealer replaced them. But they told me to only have the inside of the tire balanced. They said that putting weights on the outside would cause them to start chiping again. This problem has just come up within the last month and my jeep only has 26'000 miles. So it could be a balancing issue.
Old Dec 24, 2010 | 05:25 AM
CJ7nvrstk's Avatar
Vet Army
How is the wear pattern on those tires? It could also be d/t uneven wear.
Old Dec 24, 2010 | 05:52 AM
Michael's Avatar
Wear is good. I rotate every 5'000 miles.
Old Dec 24, 2010 | 06:50 AM
mkjeep's Avatar
Check your toe, too much toe-in will cause DW. This I know from personal experience.
Old Dec 24, 2010 | 09:47 AM
Michael's Avatar
I have'nt checked the toe. I did get a freind to turn the steering wheel and found a little slack in the track bar bushing. But I don't know how much is too much?
Old Dec 24, 2010 | 10:22 AM
Moochie's Avatar
X2.....
Old Dec 24, 2010 | 10:52 AM
TSLtrek's Avatar
https://www.jk-forum.com/forums/show...es-and-Wobbles
Old Dec 26, 2010 | 02:46 AM
Rhino64's Avatar
If you have any movement in the track bar bushing that would be my first thing to correct it should show no movement. The track bar is most likely the cause.
