Death wobble ?
I had the DW battle for 2 years until I finally got it right. I've beaten the crap out if it in Colorado and Utah, driven 80mph + afterwards and never a hint of wobble again. Be patient and you will be rewarded!
After putting a Teraflex front tracbar, Synergy trackbar brace, Currie Tie Rod on; it will still occur. Finally after putting on 9/16 bolts on the trackbar and getting a new alignment ; it vanished. Not long after I dumped the 35 MTR's for 37 Toyo MT's. solid as a rock. Honestly I think the MTR's are too soft for such a heavy 4 door and the harmonic vibrations occur easier on them. Just my theory.
Alright, need some advice. Not sure if what I'm feeling is the DW but when I hit 55/60+ mph I get a mild vibration in the steering wheel and mild shake in the tires and stick shift. I'm only running 33's and added the new SS on the front end. Do you think it's just poorly balanced tires???
Real DW will make you ask for your brown pants.. the front end will feel like it's bouncing all over and sound like the front end is exploding...
Some aftermarket SS will also cause a 'push' and may create vibrations..the stock SS is all you really need.
Thought my issue was the tires. Would start to shimmy at 40 and stop at 50. Turned out by changing out my b-joints, the shimmy went away! I think it was pre-death wobble I was experiencing.
OP...please update us...thanks!
